I wrote a script tool where a map is generated, a checkbox of layers can be checked to add the layers to the map, and when I run it some layers will add to the new map and some layers, throw "Object: CreateObject Layer invalid data source." I did notice all of the layers that error have a space in their names. They are valid layers as in when AddData is used manually they can add to a map. I know the list of the layers is a Python multiValue list, not a Python list, taking out one if the items and testing it's type yields that the item is a unicode object. I also noticed when I print the mutliValues out the ones with spaces have single quotes surrounding them and the ones w/o spaces do not have single quotes surrounding them...'file path here' Object: CreateObject Layer invalid data source 'file path here' Object: CreateObject Layer invalid data source filePathHere Added: FilePath.lyr
I convert them to layers in the script when I iterate through the multiValue list like so:try: if countyLayers[0]: for item in countyLayers.split(';'): try: item1=arcpy.mapping.Layer(item) arcpy.mapping.AddLayer(dataFrame,item1,"AUTO_ARRANGE") item2=str(item.split("\\")[-1]) arcpy.AddMessage("Added: " + item2) arcpy.RefreshTOC() del item1, item2 except Exception as e: arcpy.AddMessage(e.message) pass except: arcpy.AddMessage("No county data specified to add") pass
