Since last week's ArcGIS Online update, we've been experiencing an issue with attachments in ArcGIS Field Maps.
The data is not hosted feature layers. These are services published from ArcGIS Server and added to ArcGIS Online using the REST endpoint.
For any layer where the pop-up has been configured in Map Viewer (even something as simple as deleting the created user field), Field Maps does -
- The Attachments section appears at the bottom of the form instead of the top.
- After adding a photo, the Submit button remains grayed out.
- If another field is edited, the Submit button becomes active.
- The attribute edits are saved, but the attachment is never uploaded.
After some testing, it appears that opening the map in the field maps form editor and selecting Ungroup for all layers that have had the popup edited fixes the issue.
The issue is that this has to be done for every layer that has a configured pop-up, which is not practical for maps with many editable layers.
Is this expected behavior, or is this a bug? Do we need to go in and change all of the layers in our maps, or will this be fixed on Esri's end?
