Hey all!
I am running into the all to famous conundrums of projecting State Plane to WGS84.
I have eastings and northings point coordinates supplied by a contractor for important infrastructure, so accuracy is very important. Seemingly the data is so close, but no matter what I seem to do, all of my points are almost exactly a foot off (at least they are consistently off!).
I start by adjusting the coordinate system of the map to the State Plane projection for my area.
I then add my data coordinates, which are on a spreadsheet. I then use 'XY table to point' to create my initial State Plane projected points.
After, I have the points added, I use the 'project tool', but the WGS84 points are consistently one foot off.
I have tried inputting the vertical datum (NAVD88 is what was used for the original data... I've been curious if vertical and horizontal having different measurement types is what is impacting my results?) in both the project map and within the project tool, but keep getting similar results.
Any help is very appreciated! Thanks for the guidance!
