I have some older ArcGIS Pro projects that have layers in them from an old Enterprise GDB. That gdb is no longer available, and all the layers have been moved into the Portal. Whenever I try to set the data source for the layers in these older projects, it will not let me update them with the data in the portal. When I highlight the feature layer in portal, the OK button turns to OPEN. If I open the feature layer or double click on it, it says this container is empty. I have verified that the feature layer is in fact there and there is data in it. Any suggestions to why this would be happening?
Kevin
