Hello, I've noticed that in an ArcGIS Pro Project, when I go to Catalog pane > Project > Maps and double click a named Map there (say "Friday Map A"), while the map's title shows up just once in the Maps section of Catalog, a copy of the original 'map tab' gets created (in the row/line of tabs just above the data view type window), named "Friday Map A 2/2". If I double click it in Catalog later in the day, yet another one gets created... "Friday Map A 3/3", etc.
A couple questions: 1) Should I not be using the Catalog > Map link to open the Map view? 2) Is there a setting I can change that will cause Pro to now Copy the Map to new versions each time I double click the named map in the Catalog pane.
Thanks in advance for any help,
Dave
