I created a report. However, I cannot get the report to return the nested repeat table records. I've reviewed all the documentation. It should be pretty simple. I get nothing back for the nested repeat table section.
Am I missing something really obvious? All my field names match. Even the "report template" doesn't return the nested repeat records. The rest of the report works just fine. The repeat polygon layer is returning all those records. Everything has a unique field name.
I see other posts about nested repeat reports and I don't see any difference. I tried putting the tags inside a table in the first and last cells. Tried outside. Tried no table and just like one field. Nothing. I'M SO CONFUSED!
structure: table > repeat polygon layer > nested repeat table.
table > repeat polygon layer: globalID > Form_GUID
repeat polygon layer > nested repeat table: globalID > Field_GUID
I confirmed these nested records have the keys and GUIDs populated correctly after submission. I see the nested repeat records in the view form when I click the record in the table in Survey123.
