In ArcGIS Hub, with a Survey card... the Survey 123 once submitted displays the thank you screen but does not redirect as designed in Survey123.
This is just like in ExB, when theme is disabled - and is resolved when theme is enabled in the ExB Survey card. However, there is no "enable theme" button in ArcGIS Hub for Surveys.
The program managers like that the survey loads within the Hub site so users can easily navigate back to the site home page from the survey... however... because of a specific workflow, I need the form to redirect to an ExB app for some additional data editing that is not available in Survey123 with some nested repeat calculations.
However, in ArcGIS Hub, after submitting - it simply shows the thank you screen as designed... but there is no redirecting message and it does not redirect.
Is this a known BUG and is there any intention to either allow for enabling the survey theme in arcgis hub or allowing the redirects?
Thanks!!
