I understand that contingent values need to be generated in ArcGIS Pro before publishing as a hosted feature layer. However, I want to add some contingent values based on what a user selects for esritask_assignee. Is this possible? If I have field_assignee configured for contigent values, can have the user pick esritask_assignee and then have field_assignee calculate based on that choice, then it triggers the contingent value?
In my scenario, I only have 2 contigencies, one would be ideally using esritask_assignee and task_category (not an esritask default field). The other uses esritask_assignee and task_editor (also a field I made, not an esritask default field)
