Hello, The script below joins a table to a feature class and then copies specific features from there into a different, existing feature class. This has run smoothly for over a year, but recently there was a change in the database that the table comes from, and now the script fails at the append step. Nothing has changed on the gis-side - feature classes, locations, etc. We've been tinkering with this for months now and are not getting any closer to a solution.
The traceback we're getting has it specifically failing on the 'with arcpy.da.SearchCursor(...' line (Line 359 ). It doesn't make it to the for loop or .getMessages()
This has been tinkered with a lot since the last time it was successfully ruin. First we were told to not do a copy feature / paste feature (how it came out of Model Builder), but ratehr an insert. Then there was a question of whether or not an edit session was needed. Then we were suggested using an insert cursor... I built the original in Modelbuilder and exported to Python, which is about the extent of my skills. A colleague who is skilled in Python but new to GIS has been doing most of the work now. Any idea what might be going on? Really appreciate your help !
# Name: SurveyPlatAutomation
# Purpose: This script identifies surveys marked complete in Accela and grabs
# selected information for each from Accela. The parcel ID from
# Accela is used to select a parcel, copy its geometry to the Survey
# Plat layer in editgis, and populate the attribute table with the
# Accela field information.
# Author: mlauer@bouldercounty.gov
# Created: 01/21/2025
# Updated: 01/21/2026 - sent from Sean
# 01/28/2026 - updated connection string/query for new server
# 02/09/2026 - fixed sql query, tried arcpy Editor class
# 02/17/2026 - Editor crashed at start of run, trying InsertCursor
# 03/04/2026 - format dataframe to match feature class exactly
# 04/06/2026 - check for datum errors
# 04/16/2026 - strip csv table prefix from table before insert
from datetime import date
import os
import shutil
import sys
import time
import arcpy
import pandas as pd
import pyodbc
import smtplib
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
# new server
connection_string = (
REMOVED
query = """
SELECT *
FROM OPENQUERY([BOCO-ASYNC-PROD-DB.US.ERDB.ACCELA.COM,14332], '
SELECT V_RECORD.RECORD_ID AS survey_id
,V_RECORD.RECORD_TYPE AS docket_type
,V_RECORD.DATE_OPENED AS app_date
,V_RECORD.SHORT_NOTES AS document_title
,V_RECORD.[DESCRIPTION] AS description
,V_PARCEL.PARCEL_NBR AS parcel_id
,V_RECORD.ADDR_FULL_LINE# AS address
FROM V_RECORD
JOIN V_PARCEL ON V_RECORD.RECORD_ID = V_PARCEL.RECORD_ID
WHERE V_RECORD.DATE_OPENED >= ''2025-01-01''
AND V_RECORD.RECORD_TYPE = ''Land Survey Plat''
AND V_RECORD.[STATUS] = ''Accepted Completed''
def main():
start_time = time.time()
today = date.today()
formatted_date = today.strftime('%m/%d/%Y')
# os.system('pause')
surveys = query_accela(
connection_string,
query
split_surveys = return_by_parcel_id(surveys)
# get lists from returned dictionary
process_surveys = split_surveys['surveys']
missing_surveys = split_surveys['missing_id']
multi_surveys = split_surveys['multi_id']
# create list of features to upsert
feature_class_update = []
# lists of records containing nonetype values
surveys_with_null_values = []
# iterate through process_surveys
for survey in process_surveys:
# check for null values
if survey['survey_id'] is None:
surveys_with_null_values.append(survey)
elif survey['docket_type'] is None:
elif survey['app_date'] is None:
elif survey['document_title'] is None:
elif survey['description'] is None:
else:
# dictionary for each feature
feature_attributes = {}
# set survey_id
feature_attributes['survey_id'] = survey['survey_id']
# set parcel_id
feature_attributes['parcel_id'] = survey['parcel_id']
# set survey_type
if survey['document_title'].startswith('IMPROVEMENT'):
feature_attributes['survey_type'] = 'Improvement Survey Plat'
elif survey['document_title'].startswith('ALTA'):
feature_attributes['survey_type'] = 'Land Survey Plat'
elif survey['document_title'].startswith('LAND'):
else:
feature_attributes['survey_type'] = 'Other Type of Plat'
# set survey_descr
raw_description = survey['description']
# section
if 'SECTION ' in raw_description:
sec_abbr = raw_description.replace('SECTION ', 'SEC')
elif 'SEC. ' in raw_description:
sec_abbr = raw_description.replace('SEC. ', 'SEC')
elif 'SEC ' in raw_description:
sec_abbr = raw_description.replace('SEC ', 'SEC')
else:
pass
# abbreviate township
if 'TOWNSHIP ' in sec_abbr:
town_abbr = sec_abbr.replace('TOWNSHIP ', 'T')
else:
pass
# abbreviate range
if 'RANGE ' in town_abbr:
range_abbr = town_abbr.replace('RANGE ', 'R')
else:
pass
# abbreviate quarter
if 'QUARTER' in range_abbr:
quarter_abbr = range_abbr.replace('QUARTER', '1/4')
else:
pass
# abbreviate northeast
if 'NORTHEAST' in quarter_abbr:
ne_abbr = quarter_abbr.replace('NORTHEAST', 'NE')
else:
pass
# abbreviate southeast
if 'SOUTHEAST' in ne_abbr:
se_abbr = ne_abbr.replace('SOUTHEAST', 'SE')
else:
se_abbr = ne_abbr
pass
# abbreviate southwest
if 'SOUTHWEST' in se_abbr:
sw_abbr = se_abbr.replace('SOUTHWEST', 'SW')
else:
sw_abbr = se_abbr
pass
# abbreviate northwest
if 'NORTHWEST' in sw_abbr:
nw_abbr = sw_abbr.replace('NORTHWEST', 'NW')
else:
nw_abbr = sw_abbr
pass
# abbreviate north
if 'NORTH' in nw_abbr:
n_abbr = nw_abbr.replace('NORTH', 'N')
else:
n_abbr = nw_abbr
pass
# abbreviate east
if 'EAST' in n_abbr:
e_abbr = n_abbr.replace('EAST', 'E')
else:
e_abbr = n_abbr
pass
# abbreviate south
if 'SOUTH' in e_abbr:
s_abbr = e_abbr.replace('SOUTH', 'S')
else:
s_abbr = e_abbr
pass
# abbreviate west
if 'WEST' in s_abbr:
w_abbr = s_abbr.replace('WEST', 'W')
else:
w_abbr = s_abbr
pass
# concat document_title and abbr_description
abbr_description = w_abbr
final_description = survey['document_title'] + ', ' + abbr_description
# check for 255 chars
if len(final_description) <= 254:
feature_attributes['survey_descr'] = final_description
else:
feature_attributes['survey_descr'] = final_description[:254]
# set survey_year
feature_attributes['survey_year'] = '0000' # check with Sean...
else:
feature_attributes['survey_year'] = str(survey['app_date'].year)
# set PLSS_COORD, it will always equal 'N'
feature_attributes['PLSS_COORD'] = 'N'
# set survey_link
path = r'V:\ScannedMaps\SURVEY\LANDSURVEY''\\'
year_last_2 = feature_attributes['survey_year'][-2:]
survey_id_last_4 = feature_attributes['survey_id'][-4:]
suffix = '-01'
file_ext = '.pdf'
filename = year_last_2 + survey_id_last_4 + suffix + file_ext
feature_attributes['link'] = path + filename
# add to feature_class_update
feature_class_update.append(feature_attributes)
# accela data as a dataframe
df = pd.DataFrame(feature_class_update)
clean_df = rename_reorder_df(
df,
rename_map={
'survey_id': 'SURVEY_ID',
'survey_type': 'SURVEY_TYP',
'survey_descr': 'SURVEY_DES',
'survey_year': 'SURVEY_YR',
'PLSS_COORD': 'PLSS_COORD',
'link': 'LINK',
'parcel_id': 'PARCEL_NO'
column_order=[
'SURVEY_ID', 'SURVEY_TYP', 'SURVEY_DES', 'SURVEY_YR', 'PLSS_COORD',
'LINK', 'PARCEL_NO'
# the gis
print('GIS functions:')
# environment settings
# cleanup from previous session
print('Deleting old SurveysAdded...')
surveys_added = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\SurveyProcessing.gdb\\SurveysAdded'
arcpy.management.Delete(
in_data=[surveys_added]
)[0]
print('Saving Accela df as csv...')
# saving df as csv
accela_table = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\TableFromAccela.csv'
clean_df.to_csv(accela_table, index=False)
# csv to table
csv_table = 'csv_table'
workspace = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\SurveyProcessing.gdb'
table_output = arcpy.conversion.TableToTable(
accela_table,
workspace,
csv_table
# create table view
print('Creating table view...')
table_view = 'csv_table_view'
arcpy.management.MakeTableView(
table_output,
table_view
# temporary feature layer from feature class
print('Creating temporary layer from Parcels feature class...')
parcels = r'V:\\gislu\\_DatabaseConnection\\regis1.boco.gis.dc.sde\\boco.PARCELS.PARCELS'
parcels_layer = 'parcels_layer'
arcpy.management.MakeFeatureLayer(parcels, parcels_layer)
# join
print('Joining csv table view to Parcels feature class...')
arcpy.management.AddJoin(
in_layer_or_view=parcels_layer,
in_field='PARCEL_NO',
join_table=table_view,
join_field='PARCEL_NO',
join_type='KEEP_COMMON'
# export features
print('Exporting table to SurveysAdded feature class...')
arcpy.management.CopyFeatures(
parcels_layer,
surveys_added
# remove join
print('Removing temporary join...')
arcpy.management.RemoveJoin(parcels_layer)
# strip 'csv_table_' prefix from surveys_added fieldnames
print('Stripping csv_table_ prefixes...')
strip_prefix_fields(surveys_added, prefix='csv_table_', collision_suffix='_ACC')
# print record count of surveys_added
input_record_count = arcpy.management.GetCount(surveys_added)
print(f'Input table surveys_added has {input_record_count} records')
# target feature class
survey_plat = r'V:\\gislu\\_DatabaseConnection\\editgis1.lu.user.dc.sde\\lu.LU.SURV_SurveyPlat'
print('Schema lock test (target):', arcpy.TestSchemaLock(survey_plat))
print('Workspace type:', getattr(arcpy.Describe(os.path.dirname(survey_plat)), 'workspaceType', None))
# check for branched versioning
desc_fc = arcpy.Describe(survey_plat)
print('isVersioned:', getattr(desc_fc, 'isVersioned', None))
print('isBranchVersioned:', getattr(desc_fc, 'isBranchVersioned', None))
fields = [
'PLSS_COORD', 'LINK', 'PARCEL_NO'
# Build explicit source and target field lists including SHAPE@
src_fields = fields + ['SHAPE@']
tgt_fields = fields + ['SHAPE@']
sde_workspace = r'V:\gislu\_DatabaseConnection\editgis1.lu.user.dc.sde'
edit = arcpy.da.Editor(sde_workspace)
# Inspect target field types
tgt_field_types = {f.name: f.type for f in arcpy.ListFields(survey_plat)}
print('Target field types:', tgt_field_types)
src_field_types = {f.name: f.type for f in arcpy.ListFields(surveys_added)}
print('Source field types:', src_field_types)
try:
# open edit session
edit.startEditing(True, True)
edit.startOperation()
inserted = 0
skipped = 0
with arcpy.da.SearchCursor(surveys_added, src_fields) as s_cur, \
arcpy.da.InsertCursor(survey_plat, tgt_fields) as i_cur:
for row in s_cur:
try:
i_cur.insertRow(row)
inserted += 1
except Exception as row_error:
print(arcpy.getMessages())
print(f'ERROR - Could not insert row: {row_error}')
skipped += 1
print(f'Inserted: {inserted} | Skipped: {skipped}')
edit.stopOperation()
edit.stopEditing(True)
except Exception as e:
# roll back safely on error
if edit.isEditing:
edit.stopEditing(False)
raise
# formatted email body
# prep str for processed surveys
report_processed = f'Surveys processed: {len(process_surveys)}\n'
survey_id = survey['survey_id']
parcel_id = survey['parcel_id']
report_processed += f'{survey_id}' + ' ' + f'{parcel_id}\n'
# prep str for surveys missing a parcel id
report_missing = f'Surveys missing a parcel id: {len(missing_surveys)}\n'
for survey in missing_surveys:
report_missing += f'{survey_id}\n'
# prep str for surveys with multiple parcel ids
report_multi = f'Surveys with multiple parcel ids: {len(multi_surveys)}\n'
for survey in multi_surveys:
report_multi += f'{survey_id}' + ' ' + f'{parcel_id}\n'
# prep str for surveys with nonetype values
report_null = f'Surveys with NULL values: {len(surveys_with_null_values)}\n'
for survey in surveys_with_null_values:
survey_id = 'NULL'
else:
report_null += f'{survey_id}' + ' ' + f'{parcel_id}\n'
# assembly of email body
email_body = 'Please review following land survey plats:\n' + '\n'
email_body += f'{report_processed}\n'
email_body += f'{report_missing}\n'
email_body += f'{report_multi}\n'
email_body += f'{report_null}'
# send email function used for testing
send_gmail(
recipient='mlauer@bouldercounty.gov',
subject='Survey Plat Report - ' + formatted_date,
body=email_body
send_gmail(
recipient='sgambrel@bouldercounty.gov',
body=email_body
end_time = time.time()
run_time = end_time - start_time
print(f'Runtime: {run_time:.2f} seconds')
## END MAIN
def strip_prefix_fields(feature_class, prefix='csv_table_', collision_suffix='_ACC'):
Rename fields in `feature_class` that start with `prefix` by stripping the prefix.
If the target name already exists, append `collision_suffix` with an incrementing number.
# Build a set of existing field names (lowercase for quick membership checks)
existing = {f.name.lower() for f in arcpy.ListFields(feature_class)}
# Iterate all fields and rename those with the prefix
for f in arcpy.ListFields(feature_class):
old_name = f.name
if old_name.startswith(prefix):
base = old_name[len(prefix):] # target name without prefix
new_name = base
# Handle collisions: ensure unique name
if new_name.lower() in existing:
i = 1
while f"{base}{collision_suffix}{i}".lower() in existing:
i += 1
new_name = f"{base}{collision_suffix}{i}"
# Use the same alias as the new name (or customize here)
new_alias = new_name
# Perform the rename
arcpy.management.AlterField(
in_table=feature_class,
field=old_name,
new_field_name=new_name,
new_field_alias=new_alias
# Maintain the set to reflect the rename
existing.add(new_name.lower())
existing.discard(old_name.lower())
print(f"Renamed field: {old_name} -> {new_name}")
def rename_reorder_df(df, rename_map=None, column_order=None):
result = df.copy()
if rename_map:
result = result.rename(columns=rename_map)
if column_order:
result = result[column_order]
return result
def append_df_to_feature_class(df, feature_class, field_map=None):
if field_map:
df = df.rename(columns=field_map)
fc_fields = [
f.name for f in arcpy.ListFields(feature_class)
if f.type not in ('OID', 'Geometry') and not f.required
matched_fields = [col for col in df.columns if col in fc_fields]
if not matched_fields:
raise ValueError('No matching fields found between df and fc')
rows_inserted = 0
with arcpy.da.InsertCursor(feature_class, matched_fields) as cursor:
for row in df[matched_fields].itertuples(index=False, name=None):
cursor.insertRow(row)
rows_inserted += 1
print(f'Rows inserted: {rows_inserted}')
# InsertCursor -----------------------------------------------------------------
def resolve_joined_field(source_fc, target_name):
Find the actual field name in source_fc that matches target_name,
allowing for join prefixes like `csv_table_` or `parcels_`.
source_names = [f.name for f in arcpy.ListFields(source_fc)]
# exact match
if target_name in source_names:
return target_name
# look for suffix match like xyz_TARGETNAME
candidates = [
name for name in source_names
if name.lower().endswith(target_name.lower())
if len(candidates) == 1:
return candidates[0]
elif len(candidates) > 1:
# choose the shortest suffix match to avoid over-prefixed names
return sorted(candidates, key=len)[0]
else:
raise RuntimeError(f'Could not resolve source field for: {target_name}')
# End InsertCursor functions ---------------------------------------------------
def query_accela(connection_string, query):
try:
connection = pyodbc.connect(connection_string)
cursor = connection.cursor()
cursor.execute(query)
# get key names
keys = [key[0] for key in cursor.description]
# create list of dictionaries
results = [
dict(zip(keys, row)) for row in cursor
cursor.close()
connection.close()
return results
except pyodbc.Error as e:
print(f'Database error: {e}')
return []
print(f'Error: {e}')
return []
def return_by_parcel_id(query_returns):
surveys_with_parcel_id = []
surveys_multi_parcel_id = []
surveys_missing_parcel_id = []
if len(query_returns) > 0:
for survey in query_returns:
if survey['parcel_id'].startswith('0'):
surveys_missing_parcel_id.append(survey)
elif len(survey['parcel_id']) > 12:
surveys_multi_parcel_id.append(survey)
else:
surveys_with_parcel_id.append(survey)
else:
return False
return {
'surveys': surveys_with_parcel_id,
'multi_id': surveys_multi_parcel_id,
'missing_id': surveys_missing_parcel_id
def send_gmail(recipient, subject, body):
gmail_sender = REMOVED
gmail_app = REMOVED
try:
msg = MIMEMultipart()
# create email
msg['From'] = gmail_sender
msg['To'] = recipient
msg['Subject'] = subject
msg.attach(MIMEText(body, 'plain'))
# connect to gmail server and send
server = smtplib.SMTP_SSL('smtp.gmail.com', 465)
server.ehlo()
server.login(gmail_sender, gmail_app)
text = msg.as_string()
server.sendmail(gmail_sender, recipient, text)
server.close()
print(f'Email sent to: {recipient}')
## END OF ALL FUNCTIONS
if __name__ == '__main__':
main()
