Hi all,
I have a couple of surveys created in Survey123 Connect that had been functioning prior to the most recent Survey123 Connect update (3.25.27). Since the update, I have been getting errors on the web versions when trying to submit a record. After troubleshooting, I found the cause of the error was from hidden fields with inputMasks (ex. 9999; >XXXX9999).
Error: "Survey contains errors: 3. Press here to navigate to each error." When you press to navigate, there are no errors it takes you to.
Workaround solution: Remove inputMask parameter from the hidden fields and republish
I'm wondering if this is an additional bug from the most recent update? These inputMasks were functioning prior.
