Currently, ArcGIS Pro supports rubbersheeting for PDFs and raster datasets using multiple control points (more than two), which provides flexibility and improved spatial accuracy.
However, this capability is not available for AutoCAD/DWG files, where georeferencing is limited to only two control points.
I would like to request an enhancement to the georeferencing tools in ArcGIS Pro to enable full rubbersheeting functionality for AutoCAD/DWG files, allowing the use of multiple control points similar to PDFs and rasters.
This improvement would significantly enhance alignment accuracy and usability when working with CAD data.
Thank you for your consideration.
