I have created a Survey which asks people to draw a polygon on a map. I have selected a map for survey which as WGS1984 projection.
However when I view the resultant data on a map, or in Survey123 results, they are no longer aligned to the map, even when against the same WGS1984 base map as selected for the form.
In the Service properties it says the layers spatial reference is:
How can I choose the project of my resultant layers created when publishing the survey so it lines up?
