In nearly every widget/element designed to showcase data across ArcGIS products, you can customize the labels, order, and visibility of fields to curate a specific user experience with your data.
However, in the Feature Info widget of Experience Builder you cannot. Please allow the ability to customize how Feature Info displays information, such as changing the label of fields, order of fields, and field visibility. It would also benefit users if the View Related Records option was not hidden within the Data Action grid button but was shown within the main interface of Feature Info, akin to a web map popup. Further, if it could be customized which related record layers users could see, this would also help.
It is important that these functions are available both for Feature Info's connected to a map and straight to data.
Many thanks!
