I already posted this in Javascript Maps SDK questions, but thought I'd post it here too as well since I wasn't sure which board was more relevant.
I am using the 4.33 maps SDK and calcite 3.2.1 and I would like to have the calcite popover windows in my application always display above any other elements. Right now I have an arcgis feature table that displays above the calcite popovers. I have tried adjusting the z-index in my css for these elements, but no values seem to the achieve the desired effect.
Here is a codepen that shows the issue: https://codepen.io/windowslover/pen/ByLLmrP
If I set the z-index to -1 in my #tableDiv css rule the feature table no longer appears above the popovers but then it displays behind the arcgis-coordinate-conversion widget and bottom application attribution, which is not desired.
Is there a css variable or some other setting that I can use to get the desired effect where the arcgis-feature-table is right below calcite popovers in z-index arrangement?
Edit: I forgot to mention you can drag/resize/expand the feature table with the button and edge of the feature table.
