I am getting the following error:
./node_modules/@arcgis/core/node_modules/@esri/calcite-components/dist/cdn/main.css:1:0 - Error: Module parse failed: Unexpected character '@' (1:0)
You may need an appropriate loader to handle this file type, currently no loaders are configured to process this file.
This issue has been presented in other threads. However, I still seem to get the issue in v5.0. I am confused as to what the issue is. I have followed multiple solution threads and nothing works.
I have read through the PRs in this github PR and it doesnt solve my solution
Version 3.3.0 distributes a file with invalid CSS that breaks Angular testing (`ng test`). Also affects ArcGIS packages. · Issue #12931 · Esri/calcite-design-system
I followed the Potential Solutions in the above link.
I first updated to angular 21. Surely if angular 20 could fix the parsing error. Then Angular 21 should be no different. This still didn't build the calcite-component.
next I built a custom WebPack where we compiled the .main.css using postCSS. This "Solved" the one issue with calcite-component.main.css But then the light.theme.css had issues building.
Is anyone else still having these issues building their angular apps?
