I have a survey published from Connect where a user is doing Property Assessments on existing parcels.
The inbox is setup, and the List tab works as it should, but I am not able to select the parcel polygon in the Map tab and open the survey for that parcel.
Does the Map tab only work when selecting points, not polygons? Or am I missing a step?
