Happy new year!
I'd like to create an app with maps and graphs using Arc Experience Builder and I've come up against what seems to be a limitation...
I'm looking to publish an app with map and related chart that allows users to explore many different variables/fields within a feature layer (relating to nitrogen in water). I've got 10+ different variables, including for example modelled nitrate-nitrite nitrogen, modelled ammonical nitrogen, etc.
I've figured out how to create an action so that the chart changes to reflect changes in the extent of the map (see below).
What I need to do is configure the app so that the chart changes when the user changes the map layer and/or zooms in/out and changes the map extent.
However, the chart doesn't change even though I changed the map to Modelled ammonical nitrogen.
An issue seems to be that chart app seems to be able to interact with a single and specified layer in the map widget only. It is not clear whether it is possible to make my Experience Builder chart category field reactive to map selections.
https://support.esri.com/en-us/knowledge-base/synchronize-charts-based-on-the-selection-in-a-chart-us-000033870 suggests that
Selecting 'Framework' will filter this layer across the application, including the second chart and the map.
However, when I select a trigger and click Record selection changes - I don't appear to have the option of choosing "Framework" as the Target.
Does anyone know how to resolve this?
