Hi dear community, I am fighting with this stuff around 5 months....So I'm working on a survey for field measurments in water (pH, EC, DO, etc) so my field workers should run a qaqc measure when they rich 10 samples of water. Translate to survey123, I already set the question "qaqc" so that every 10 repeated answers that includes a resutl, shows a decimal question in which the worker should put the value of the qaqc. At this point everything works, but when I tested the survey with 20 answers, when I try to navigate to the previous or even the 15 or 4th anwer, the "qaqc" question appears in every record....
This is a problem that I can´t solved it since I need that the "qaqc" question only appears every 10 records and when I want to go back to previous ones, it doesn't request data.
If anyone knows how to made it, I will really appreciate it because I had work in this for months with no possitive results.
Thanks in advance to everyone who can give me a hand.
By the way....I can't share my entire survey because it's confidencial and I can´t share much of this innovation in my country, sorry for that by I will give any details you need.
