I am attempting to clone my Python environment on a new PC running ArcGISPro 3.4.3, and I get the following error:
> "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda.exe" create --clone "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3" -p "C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone" --no-shortcuts --pinned --yes
CondaHTTPError: HTTP 404 NOT FOUND for url <https://conda.anaconda.org/esri-build/win-64/vc-14.38-0.conda>
Elapsed: 00:00.157106
CF-RAY: 9bad35408b1ba548-MIA
An HTTP error occurred when trying to retrieve this URL.
HTTP errors are often intermittent, and a simple retry will get you on your way.
CondaHTTPError: HTTP 404 NOT FOUND for url <https://conda.anaconda.org/esri-build/win-64/vs2015_runtime-14.38.33130-0.conda>
Elapsed: 00:00.185534
CF-RAY: 9bad35408f058c20-MIA
Source: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
Destination: C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
Packages: 280
Files: 15
Copying pinned file from C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\conda-meta\pinned to C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\conda-meta\pinned
Downloading and Extracting Packages: ...working... done
Cleaning up...
Destination folder removed.
I tried going to the URL that is indicated as having a 404 error, and it is indeed blank. Is there an alternative method I can try? It seems that Anaconda is changing their website.
Thank you!
