We have a one-off situation at the boundary of two pressure zones in our system. There's a segment of pipe that apparently had a pretty shallow bury, and the solution to prevent freezing was a small bypass left open (see below). This allows a trickle flow of high pressure to come through from high pressure to low so the water is always moving and doesn't have a chance to freeze.
Right now, I just have the valve closed to allow the pressure subnetworks to work properly. Ideally, I would like to be able to meet the following criteria:
- Show valve as open
- Establish pressure zone change
- Return as a valve that needs to be closed on Isolation traces
Any suggestions for this? I know I could set a new class of subnetwork controller, but that seems heavy handed and I'm not sure if that would interfere with the isolation return. If only the engineers had spec'd a check valve...
