How does one create custom icons for use in Survey123 for use in drawing on a map? I find the documentation a bit confusing.
Are there step-by-step instructions somewhere that will help one through the process of icon creation?
The people I work with inspect septic tanks and other icons as seen in the attached example. The background should be transparent.
I've attempted to use the geotrace, geodraw, etc. but the process seems to leave less than a polished result.
The documentation has some interesting points and the palette helps to a certain extent, however the reports in which the icons will be seen a required to look crisp and show shapes that will be recognized immediately.
The have a need for use of 9 icons from which to choose.
Thanks for any help.
