I have a repeat section with a geopoint question, but for each location that gets recorded, the map on which the point is placed appears empty. Is it possible to see the map populated with the points previously collected as part of the repeat section in that form?
Say, the first iteration of the repeat section, when collecting the geopoint, the map will be empty, as it's the first one. But on the second iteration, the first location is visible. And on the third one, the first and the second are also visible.
This is to aid with the data capture as some of the positions we record can be supported by showing the relative positions to other features (e.g. tree positions inside a woodland).
I have seen some comments out there suggesting expressions in the that body::esri:style and bind::esri:parameters but so far I've had no joy when testing this.
TIA
