When editing a hosted feature layer within ArcGIS Pro, any edits made inside the attribute table are not saved when the layer is reopened in a new project or after the same project is closed and reopened again. The save edits button is pressed every time and the edits stay within the attribute table until the project is closed. Edits made with geoprocessing tools and edits made inside the attribute window are saved when the project is reopened, but anything done inside the attribute table disappears. Anyone else have this problem? This doesn't occur on feature classes in any geodatabase type or shapefiles. I know a solution can be to use geoprocessing tools or attribute window to edit, but there are quite a few times where we don't have enough edits to justify running an entire geoprocessing tool, but enough edits that make it annoying to click through all of them in the attribute window. Using ArcGIS Pro 3.5.4.
