Hello everyone,
I’m experiencing an issue with Survey123 and would appreciate any guidance.
Here’s the situation:
- I created a new survey using Save As from an existing survey.
- After configuring the new survey, I published it successfully.
- Later, I made some adjustments by adding new fields and republished without any problems.
- The issue occurs when I try to remove a question. After removing it and attempting to publish, I receive the following error: "500: Field name 'keywords' does not exist"
I’ve checked the related feature layer, and editing is enabled. I also reviewed the network traffic logs but couldn’t find any additional details about the error.
Thank you in advance
