Hi.
I'm trying to use ArcGIS API for Python to run a simple query on two layers from the same service.
https://arcgisv11.sea.gob.cl/server/rest/services/WEBServices/ProyectosSEIA/MapServer
Using this sample code I try to create a dataframe from the layer data and it works the EIA layer (1) but not in DIA layer (2) even if the layers are almost identical
import pandas as pand
from arcgis.gis import GIS
from arcgis.features import GeoAccessor, GeoSeriesAccessor, FeatureLayerCollection
gis = GIS()
fs_url=r"https://arcgisv11.sea.gob.cl/server/rest/services/WEBServices/ProyectosSEIA/MapServer"
coleccioncapas = FeatureLayerCollection(fs_url)
Capas=coleccioncapas.layers
#for capa in Capas:
# print(capa.properties.name)
capa_data=Capas[1]
df_data = pand.DataFrame.spatial.from_layer(capa_data)
print(df_data.head(5))
That's the error.
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\urllib3\connectionpool.py:1097: InsecureRequestWarning: Unverified HTTPS request is being made to host 'arcgisv11.sea.gob.cl'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#tls-warnings
warnings.warn(
warnings.warn(
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\requests\models.py", line 974, in json
return complexjson.loads(self.text, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
During handling of the above exception, another exception occurred:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\geo\_accessor.py", line 2683, in from_layer
return from_layer(layer=layer)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\geo\_io\serviceops.py", line 186, in from_layer
sdf = layer.query(where=query, as_df=True)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\layer.py", line 2257, in query
).execute()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 658, in execute
return self._query(raw)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 679, in _query
return self._handle_query_exception(query_exception)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 843, in _handle_query_exception
raise query_exception
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 677, in _query
return self._process_query_result(result, raw)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 711, in _process_query_result
features = self._fetch_all_features_by_chunk()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\_impl\common\_query.py", line 829, in _fetch_all_features_by_chunk
result = future.result().json()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\requests\models.py", line 978, in json
raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
requests.exceptions.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File "d:\Code\core-python-jupiter\pruebas\testing.py", line 12, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\geo\_accessor.py", line 2687, in from_layer
raise Exception(
Exception: Malformed response from server, could not load the dataset: Expecting value: line 1 column 1 (char 0)
