Hi! I recently created a StoryMap (https://storymaps.arcgis.com/stories/4a9b075c420d4455b3fc9483faa113fa) which was a was sometimes a little slow to load, but ever since I updated the underlying data there is an entire section of embedded maps (in the Ministry Types section) that will not consistently load. There are eight sidecars in a row, seven of which have a map as the first slide. I can't get all of these maps to load at the same time, and every time I refresh the page a different combination of the seven maps will load. Is this an issue with having too many maps in one storymap (if that's even possible?), a network issue (I have better luck loading them on my phone when my phone is on data only, though most times I get two sidecars in and the website crashes), or is there some underlying thing broken?
For further information- originally, I had one map with 14 layers, 2 for each ministry type. After updating the data I was no longer able to edit that map's settings where it was used in the storymap. So I re-uploaded the dataset with a different name and made a map for each ministry type (ie 7 maps with 2 layers each). That definitely helped but I still can't get them to consistently load! And the kicker is that a different set of maps using the same dataset work just fine.
I have both cleared my cache and turned off ad blocker.
