There are 2 ways the Filter widget lacks customization and its default behavior makes it harder for users to get the info they want.
1) Despite setting my filter to display "All unique values of this field" within the SQL expression builder within the value dropdown, the values available for selection sync with those present in the current map extent. Please allow the full list to be available regardless of map extent, so users aren't misguided on what values are present in the data to select from.
I do not see where I can toggle this syncing on or off. Please allow this to be on/off.
2) Despite setting my filter to display "All unique values of this field" within the SQL expression builder within the value dropdown, an A-Z list of author names in my data gets cut off around the "D" authors. This is when the map's extent encompasses all features in my data. While users can search for authors from E onward, it seems the display for a filter's choices caps out independent of the data--again, misleading users to think there are fewer data than there are.
I do not see where I can set a max count of returned options for a filter dropdown. Please allow this to be set by us.
Note: This behavior is occurring without the Filter widget receiving any actions from other widgets.
