I'm trying to set up some data expressions in Dashboards to use with Indictor widgets. I have a tracts layer (322 features) and a lakes layer (11,200 features) and I want to intersect these to get the total number of lakes and a sum of lake acres in the Indicator. Here is the code, which appears to work, but takes about 20 minutes to run. What can I do to speed this up? Can I run an intersection before the loop to filter out most of the lakes? There should only be about 1,020 lakes that actually intersect with the tracts. I only know a little Arcade; most of this was done with the help of CoPilot.
var port = Portal("https://www.arcgis.com");
// Load layers with correct area field name
var tracts = FeatureSetByPortalItem(port, "b9fcbedac0384e32bc3dba6aec1a8cf6", 0, ["OBJECTID"], true);
var lakes = FeatureSetByPortalItem(port, "5564b2e702364aefba08df8c95216a1f", 0, ["OBJECTID", "Shape__Area_2"], true);
var fsDict = {
fields: [
{ name: "OBJECTID", type: "esriFieldTypeOID" },
{ name: "LakeCount", type: "esriFieldTypeInteger" },
{ name: "Acres", type: "esriFieldTypeDouble" }
geometryType: "",
features: []
for (var t in tracts) {
var tractGeom = Geometry(t);
var lakeCount = 0;
var totalAcres = 0;
for (var lake in lakes) {
if (Intersects(Geometry(lake), tractGeom)) {
lakeCount += 1;
totalAcres += lake["Shape__Area_2"] / 4046.8564224;
Push(fsDict.features, {
attributes: {
OBJECTID: t.OBJECTID,
LakeCount: lakeCount,
Acres: Round(totalAcres, 1)
return FeatureSet(fsDict)
