I installed @ArcGIS/map-components.
I want to view a simple webmap.
import '@arcgis/map-components/components/arcgis-map';
export default function MapView() {
return (
<arcgis-map
// portal-url='https://my-portal-url.com/portal'
item-id='abc123c5f0314db9a487a9b46cb37eca'
style={{ height: '400px' }}
></arcgis-map>
I get something like:
Failed to load web map
Failed to load portal item
https://www.arcgis.com/sharing/rest/content/items/abc123c5f0314db9a487a9b46cb37eca
Item does not exist or is inaccessible.
Fair enough, because my webmap is not on ArcGIS Online; I'm using ArcGIS Enterprise.
How can I indicate that my portal URL is https://my-portal-url.com/portal ?
I tried adding a portal-url property to arcgis-map (commented out above) but it didn't change anything.
I tried loading the portal URL with @ArcGIS/core esriConfig first and it didn't change anything.
import { useEffect } from 'react';
import esriConfig from '@arcgis/core/config';
useEffect(() => {
esriConfig.portalUrl = 'https://my-portal-url.com/portal';
return (
<div style={{ width: '100%', height: '400px' }}>
<arcgis-map item-id='abc123c5f0314db9a487a9b46cb37eca' style={{ height: '400px' }}></arcgis-map>
</div>
Seems very basic, maybe silly... what am I missing?
Thanks in advance for your help!
