I am using ArcGIS Runtime 200.3
I have set up a named trace to do an Valve Isolation Trace. I can run the trace successfully in Pro against a mobile geodatabase containing UN. The only input parameter I am providing is the starting point.
I then tried running the same trace using .net sdk, which I have created using sample codes from Offline utility networks in ArcGIS Maps SDKs for Native Apps
I am using same the same starting location i.e. in same DMA, same named trace, same mobile geodatabase in both Pro and .net
But in .net, I am getting error:
"Tracing failed. Invalid subnetwork controllers found".
I can see there is a valid subnetwork controller for this particular DMA.
At other starting points (different DMAs), the trace works successfully in both .net & Pro.
Any idea why the trace could possibly fail using .net SDK, while it works in Pro
