Hi all,
New user here, and an ArcGIS beginner. I'm a spatial science student still learning how to use ArcGIS. I am doing the tutorials, successfully until now. I can't get the summarize invasive speices model (tutorail here) to work. The error details are:
Summarize Invasive Species
Tool Path
\\Mac\Home\Documents\ArcGIS\Packages\Make a geoprocessing model_d57e3d\p30\Make a geoprocessing model.atbx\SummarizeInvasiveSpecies
Parameters
Human Contact Locations Campsites
Buffer Distance 1.5 Kilometers
Invasive Species White Edged Nightshade Range
Area Unit of Measure HECTARES
Output Feature Class \\Mac\Home\Documents\ArcGIS\Packages\Make a geoprocessing model_d57e3d\ModelOutput.gdb\Output
Messages
Start Time: Thursday, October 30, 2025 3:25:00 PM
Executing (Pairwise Buffer): PairwiseBuffer Campsites "\\Mac\Home\Documents\ArcGIS\Packages\Make a geoprocessing model_d57e3d\commondata\make_a_geoprocessing_model.gdb\CommCamp_Buffer" "1.5 Kilometers" NONE # PLANAR "0 Meters"
Start Time: Thursday, October 30, 2025 3:25:01 PM
Succeeded at Thursday, October 30, 2025 3:25:03 PM (Elapsed Time: 1.98 seconds)
Executing (Summarize Within): SummarizeWithin "\\Mac\Home\Documents\ArcGIS\Packages\Make a geoprocessing model_d57e3d\commondata\make_a_geoprocessing_model.gdb\CommCamp_Buffer" "White Edged Nightshade Range" "\\Mac\Home\Documents\ArcGIS\Packages\Make a geoprocessing model_d57e3d\ModelOutput.gdb\Output" KEEP_ALL # ADD_SHAPE_SUM HECTARES # NO_MIN_MAJ NO_PERCENT #
Start Time: Thursday, October 30, 2025 3:25:03 PM
ERROR 100014: Summarize Within failed.
Failed script Summarize Within...
Failed to execute (Summarize Within).
Failed at Thursday, October 30, 2025 3:25:06 PM (Elapsed Time: 3.52 seconds)
Failed to execute (SummarizeInvasiveSpecies).
Failed at Thursday, October 30, 2025 3:25:07 PM (Elapsed Time: 7.68 seconds)
If any one has some advice, I'd appreicate it. I have read that this is a common issue, and there are several different fixes (see here), for example shortening/amending file names, but I am not sure which one to try, nor exactly how to do it.
David
