I'm wondering if anyone can assist with a data expression, or let me know if what I am aiming for is not possible.
I have a dataset from wildlife monitoring, which captures the date of a species observation, the lifestage (e.g. adult, juvenile), the sex (male, female, unsexed) and the quantity (integer) observed. Multiple observations can occur on the same date. Each combination of the above fields is on a separate row (i.e. in 'long' format). Example below.
| date | lifestage | sex | quantity |
| 01/03/2025 | adult | male | 2 |
| 01/03/2025 | adult | male | 5 |
| 01/03/2025 | juvenile | | 3 |
| 02/03/2025 | adult | female | 8 |
| 05/03/2025 | metamorph | | 1 |
| 05/03/2025 | adult | male | 3 |
| 12/03/2025 | adult | | 12 |
| 14/03/2025 | adult | female | 6 |
| 14/03/2025 | adult | female | 4 |
I am trying to use the Dashboards Table element to produce a summary table of this data, where each date is represented as a row, and then subsequent columns show the daily total for each lifestage*sex combination. For example:
| date | adult male | adult female | adult unsexed | juvenile | metamorph |
| 01/03/2025 | 7 | 0 | 0 | 3 | 0 |
| 02/03/2025 | 0 | 8 | 0 | 0 | 0 |
| 05/03/2025 | 3 | 0 | 0 | 0 | 1 |
| 12/03/2025 | 0 | 0 | 12 | 0 | 0 |
| 14/03/82025 | 0 | 10 | 0 | 0 | 0 |
I've gotten so far using Filter and GroupBy statements to summarise counts by day (e.g. resulting in the table format below), but I've not been able to produce a 'wide' format table. Is there any way of doing this?
| date | type | total |
| 01/03/2025 | adult male | 7 |
| 01/03/2025 | juvenile | 3 |
| 02/03/2025 | adult female | 8 |
I have based my code so far on this example: https://github.com/Esri/arcade-expressions/blob/master/dashboard/dashboard_data/CombineMultipleLayers(SerialChart).md, but instead of referencing different layers for each variable, I have tried setting up multiple FeatureSets from the same layer, each with a different filter applied (e.g. for each 'type' above).
I have also produced something similar to my incorrect output above using the List element, but it still doesn't achieve what I am after.
Any help would be hugely appreciated.
