My organization is using an Experience Builder app with the Near Me widget to replace our existing Public Notification app that was built using Web AppBuilder and the Public Notification widget. With WAB's Public Notification widget, the widget had the ability to simply inherit from the webmap's popup which fields to include in the CSV export. We would like Experience Builder's Near Me widget to have the same ability. Users should have the option to configure the Near Me widget's analysis to either include user-defined fields (as is currently the case) or simply use the webmap's settings.
The reason this option is important for our organization is because address information is not handled uniformly between all records in our dataset. Instead, we use arcade in the webmap's popup to determine which fields should be used to construct each address. We would like to be able to configure ExB's Near Me widget to inherit this webmap configuration. The way it is now, with the user having to define the fields, the output CSV contains a mess of fields, only some of which are needed for any given record. It is creating far more manual work for our end users downstream in the output CSV.
