This will be admittedly tricky because I can't show any of our data. The (highly truncated) image below shows the very top line of the information that appears in the edit widget panel when a parcel is selected in an experience I am working on. It is the county name, and I don't want it. I'd like it to be either the parcel id or blank. I cannot figure out where the 'decision' to display this field is being made. The popup of the layer does not include the county field and the form as configured in the map ('use map settings' is selected) does not have the country field in it. This value apparently has nothing to do with either the form-settings or the popup configuration, but I cannot find where in edit widget settings it can be controlled. Is it possible to change/remove this value?
Thank you,
Randy McGregor
