I'm trying to develop with Web AppBuilder for Developers.
Having a hard time with proxy configuration.
Used the following tutorial, but with no success:
Setting up a Proxy | Support Services Blog
Setting up a proxy with Web AppBuilder Developer Edition | Support Services Blog
My Scenario:
- ArcGIS Server on: https://server.virtual.private:6443/arcgis/manager/
- Portal for ArcGIS on: https://server.virtual.private:7443/arcgis/home/
ArcGIS for Server and Portal for ArcGIS was installed with WebAdaptor, checked the following urls, and everything is working:
http://server.virtual.private/arcgis/rest/services
http(s)://server.virtual.private/arcgis/home/ (working on both protocols)
Services used on app:
http://server.virtual.private/arcgis/rest/services/SampleWorldCities/MapServer
Create a app with default options (default 2d), with map that used the SampleWorldCities service.
Registered the Web App on Portal for ArcGIS and get a App ID and App Secret.
(PS: I not using ArcGIS Online).
I'm using Windows 7 with IIS 7 on my local machine to develop...
installed the proxy on IIS from the following address:
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
Used the DotNet version, converted to Application, set the pool to use .NET 4.0, and tested entering using the url:
http://mymachineip/DotNet/proxy.ashx and got a
{"error": {"code": 400,"message":"This proxy does not support empty parameters."}}
I think this is a OK response
Ok. Following tutorial, registered App on Portal for ArcGIS using the App ID, downloaded the app, put on IIS.
Then, when I try to access, I received a message asking my login and password, because I don't have permission (I don't have configured proxy yet)!
If I enter the username and password of a user of Portal for ArcGIS, everything was working correctly.... so, time to configure the proxy.
Looking at tutorial, I modified proxy.config (from DotNet application) with the following information:
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*" mustMatch="true">
<serverUrls>
<serverUrl url="http://services.arcgisonline.com" matchAll="true" />
<serverUrl url="http://server.virtual.private/arcgis/sharing/rest"
clientId="wWUNYgmDOth4p4Qx"
clientSecret="79818e1d6f2a4a5ba6b94a7d2bf85fb0"
matchAll="true" />
<serverUrl url="http://server.virtual.private/arcgis/rest/services"
username="siteadmin"
password="secret"
matchAll="true" />
</serverUrls>
</ProxyConfig>
I really don't know what put on the url, clientID and clientSecret (on clientID and clientSecret I have put the same information that was on Portal for ArcGIS - App ID and App Secret - all the documentation I read were not clear to tell me what should I put).
In config.json (of web app), I have put the following information:
"httpProxy": {
"useProxy": true,
"alwaysUseProxy": false,
"url": "",
"rules": [
"urlPrefix": "http://server.virtual.private/arcgis/sharing/rest",
"proxyUrl": "http://host-vm/DotNet/proxy.ashx"
"urlPrefix": "http://server.virtual.private/arcgis/rest/services",
}Tried again access the app (on IIS with proxy), but still asking for username and password.
Looking at chome dev tools, there's a warning message with following content:
Any helps?
