I installed the PAT Add-In and try to run the Level1 test, but it's not working. Trying to find out why. It creates the SystemInfoFile, but it looks like it can't find the file afterwards.
On a different configuration it works without problems.
C:\Temp\ProPAT>RUNME_Level1Tests
*** ArcGIS Pro PAT (Performance Assessment Tool) ***
*** Executing Level 1 Tests ***
*** DO NOT CLOSE THIS WINDOW DURING EXECUTION ***
*** REFRAIN FROM USING THE MACHINE WHILE THESE TESTS ARE RUNNING ***
*** The PerfTools ArcGIS Pro Start Utility will launch and control ArcGIS Pro ***
*** ArcPy scripts will also silently execute ***
*** This command window will close when finished ***
*** ArcGIS Pro PAT is NOT supported by Esri Technical Support ***
*** Please email perfqatools@esri.com with any issues ***
arcProDir = "C:\Program Files\ArcGIS\Pro\"
File "C:\Temp\ProPAT\Tests\RunLevel1Tests.py", line 19, in <module>
GenerateSystemInfo.GetInfo(SystemInfoFile)
File "C:\Temp\ProPAT\.\Tests\Uses_ArcPy\Common\GenerateSystemInfo.py", line 15, in GetInfo
GPU = subprocess.check_output("wmic path win32_VideoController get name")
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\subprocess.py", line 466, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\subprocess.py", line 548, in run
with Popen(*popenargs, **kwargs) as process:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\subprocess.py", line 1026, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\subprocess.py", line 1538, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
FileNotFoundError: [WinError 2] The system cannot find the file specified
C:\Temp\ProPAT>
Any clue?
