First off, THANK YOU for adding the ability to add custom pane sets to ArcGIS Pro. They are proving to be very helpful. I would like to suggest an enhancement, though. My biggest issue with the panes is that I typically use a laptop plus 2 monitors. I have the map/layout view on the main monitor and then all the "other" panes undocked on a different monitor. I do have to use just the laptop occasionally. When I go from multiple monitors to one small screen, I close/dock/collapse the panes to get more real estate. Then when I'm back in the office, I have to pin them all and drag them back out. While it's nice to at least get the panes I want back, I still have to go in pin and undock everything.
I would like to be able to have a set specifically devoted to having everything collapsed and the rest undocked.
Or maybe just a toggle that will collapse/expand all the visible panes at once?
