I have a Layout with one Map Frame; this contains only a WMS which is limited to display between 1:4724 and 1:18,897.
My Map Frame is set to 1:10,000 in Properties > Display Options > Location Settings. This falls within the acceptable scales and I can see the WMS clearly on the Layout tab.
When I run Export Layout (to PNG, 300dpi), the WMS content does not show in the output, just the text "This dataset is only viewable at the scales between 1:4724 and 1:18,897. You requested the layer at 1:3,200."
I need to export my layout at 1:10,000 with the data visible as expected. Where is 3,200 coming from?
Further: I added a locally-stored image layer and set the scale visibility to be the same min and max values. This also shows the same issue on export, and the layer is not visible. So this is not confined to the WMS but seems to be an issue with exporting.
How can I get my export at 1:10,000?
As my desired layer is a WMS I cannot alter its scale restrictions, so I need to fix the export scale.
(ArcGIS Pro 3.4 on Windows 11)
