My client deployed an experience in their Portal Server. Both their deployed experience have same domain.
Upon successful login to Portal, my client expect when they access the deployed experience they will not be challenge by login again.
However, it doesn't behave like that. My client still need to login again at least once in the deployed experience. The login popup seems acknowledge the ArcGIS token from the Portal login earlier since it only 'Allow' to access application rather than login form.
FYI, I'm testing this using named login as well as SAML authentication
Does the prompt happen because the application load too fast before even the entire credentials checking happen or by design user need to at least login once even they already successful login using ArcGIS Portal?
EXB Dev Ed version - 1.17
AGE version - 11.3
