I recently used untools 3.5.1 to create a utility network at version UN5 using the asset package to geodatabase. I copied this UN5 dataset into my test sql server sde environment. The main reason I wanted UN5 is to use the UN within my 10.9.1 enterprise. But now when trying to publish as a feature service the analyze complains that the dataset version is later than is supported by my server. I just installed ArcGIS Server UN patch 8 and still have the problem. My thinking is that it’s not the UN version, but that the dataset was created with Pro 3.5 with perhaps unsupported data types. Does this sound right? I know 2.9 is the supported Pro that works with 10.9.1 but I doubt it would support untools 3.5.1. Is there any work around for what I’m trying to do? The conundrum is I need a recent version of Pro to go through the workflow of migrating and creating a UN, but I need to use the created UN in an older version of enterprise.
