I was wondering about how overriding tintColor is supposed to work when using a local dictionary renderer.
The relevant snippet of my arcade expression is the following
keys += ';SymbolType_' + $feature.SYMBOL_TYPE;
keys +=';po:rotated|Rotation|';
var rot = (360 - $feature.ROTATION) + 90;
keys += rot;
keys += ";po:rotated|tintColor|#FF0000FF";
I've also tried using [255,0,0,255], "255,0,0" for overriding the color. I've used TintColor, tintcolor etc.
The CimPictureMarker that is being used looks like this.
"type": "CIMPointSymbol",
"symbolLayers": [
"type": "CIMPictureMarker",
"primitiveName" : "rotated",
"enable": true,
"anchorPointUnits": "Relative",
"dominantSizeAxis3D": "Y",
"size": 12,
"billboardMode3D": "FaceNearPlane",
"invertBackfaceTexture": true,
"scaleX": 1,
"colorLocked" : false,
"tintColor" : [255,0,0,255],
"url" : "../../../../../../flags/icons/default_symbol.svg"
"haloSize": 1,
"scaleX": 1,
"angleAlignment": "Display",
"version": "2.0.0",
"build": "8933"
}Again, I've tried with both an svg and png. While the JSON defined tintColor works with both, the arcade expression only accomplishes making the feature be invisible. I've also verified that no errors are logged in the console.
I understand that this example is incomplete as I am unable to provide a complete example due to time constraints.
Any input would be appreciated.
