Hi everyone, hope u are doing great 😎
We are currently working with a client who is using Survey123 surveys and has encountered a question regarding GPS functionality that I hope you can assist with.
In these surveys, the device's GPS location is very important, as photographs are included with a watermark displaying the location. This also helps confirm that the respondent has actually visited the site rather than completing the survey remotely.
At present, when the survey is opened with GPS disabled, a notification appears. However, if the user taps “Retry,” the window simply disappears. It appears that previously the survey would not allow continuation until GPS was enabled, although this has not been confirmed. We have observed that the survey can then be completed with coordinates set to 0,0. We have not found any configuration parameter that enforces GPS availability before submission, and while the behavior seen in the attached video seems unusual, it may have always functioned this way.
I am attaching a video that shows this behavior.
Could you please clarify whether this is the expected behavior, and whether there is a way to require GPS to be enabled before a survey can be submitted?
