Currently the widget controller is floating and the widgets are all centered. If you add another widget it moves the existing ones and everything stays centered in the controller. I'd like to be able to have an anchor point like an element in a layout (ArcGIS Pro).
This way I don't have to resize the widget controller and move it manually to anchor it at a specific point. I have an EB template I use for projects and some projects don't require certain widgets, but if I remove it I have to also reposition the widget controller so it looks neat.
If we could just choose top, bottom, left, right, or center (currently only option) for the widget controller to be anchored then when we add widgets they extent in correct direction (e.g. with top you add a widget and the top of the controller doesn't move but the entire controller extends downward).
