Every time I update some Z values (frequently, unfortunately), I have to change the units from feet to meters.
The vertical units of the layer in question are meters.
I have:
-changed the Map Properties/Coordinate System/Current Z to a height systems in meters
-set the Project/Options/Units/Distance Units default as meters.
Even after saving, closing, and re-opening, I still have to change the "ft" to "m", otherwise my values will be off by a factor of 0.3048.
