Hi All,
I'm trying to automate a OD matrix process using arcpy.nax and multi-processing capabilities. I'm running into errors with how to set up the multi-processing capabilities without running into a BrokenProcessPool error.
I have set up unique job gdb to write the outputs into and set up a parameter list (shown below) for a ProcessPoolExecutor.
jobs = [{'Name': #Job Name, str value
'Network': #Str path to network dataset, is shared across jobs
'Type': #Type of Job (part of Name), plain str value
'Job Path': #Path of unique job geodatabase,
'Origins': #Path of origins FC in shared GDB across jobs,
'Destinations': #Path of destinations FC in shared GDB across jobs,
'Point Barrier': #Path of point barriers FC in shared GDB across jobs}]
Below is my code that keeps breaking, I have tried to put in print statements within the try/except loop but BrokenProcessPool occurs immedately.
def run_od(job):
try:
arcpy.na.MakeNetworkDatasetLayer(job['Network'], job["Name"])
nd_travel_modes = arcpy.na.GetTravelModes(job["Name"])
travel_mode = nd_travel_modes["TruckTravelTime"]
odcm=arcpy.nax.OriginDestinationCostMatrix(job['Network'])
odcm.travelMode = travel_mode
odcm.lineShapeType = arcpy.nax.LineShapeType.NoLine
pbarriers_FM=odcm.fieldMappings(arcpy.nax.OriginDestinationCostMatrixInputDataType.PointBarriers)
pbarriers_FM['BarrierType'].mappedFieldName ='TYPE'
pbarriers_FM['Additional_Time'].mappedFieldName ='WAIT'
FM=field_mapping(odcm, job['Type'])
odcm.load(arcpy.nax.OriginDestinationCostMatrixInputDataType.Origins, job['Origins'], FM[0])
odcm.load(arcpy.nax.OriginDestinationCostMatrixInputDataType.Destinations, job['Destinations'], FM[1])
odcm.load(arcpy.nax.OriginDestinationCostMatrixInputDataType.PointBarriers, job['Point Barrier'], pbarriers_FM)
print(f"Solve OD {job['Name']}")
result=odcm.solve()
output_lines=os.path.join(job["Job Path"], f"OD_{job['Name']}")
if arcpy.Exists(output_lines):
arcpy.management.Delete(output_lines)
print(f"Export OD to Lines")
result.export(arcpy.nax.OriginDestinationCostMatrixOutputDataType.Lines, output_lines)
return f"Success - {job['Name']}"
except Exception as e:
return f"Failed - {job['Name']}"
multiprocessing.set_start_method("spawn", force=True)
with ProcessPoolExecutor(max_workers=2) as executor:
futures = [executor.submit(run_od, j) for j in jobs]
for future in as_completed(futures):
print(future.result())Running the run_od function sequentially across jobs works, just the multiprocessing step raises error. I have not edited the env parrel processing factor, I do not know if this helps/hinder process with arcpy.
Any help on this would be greatly appreciated.
Conor
