import arcpy
import os
from collections import defaultdict
from arcpy import AddFieldDelimiters, Describe
import time
start = time.time()
# === Setup ===
gdb_path = r"C:\Users\Administrator\Desktop\Downloaded\QC02002-ESA-MOD-BIM-ARC-06-V06-00001 (1).gdb"
arcpy.env.workspace = gdb_path
columns = os.path.join(gdb_path, "Spaces_BIMFileToGeodatab")
footprint_fc = "Columns_Footprint"
footprint_path = os.path.join(gdb_path, footprint_fc)
count_over = os.path.join(gdb_path, "count_over")
count_over_tab = os.path.join(gdb_path, "columns_tab")
singlePart = os.path.join(gdb_path, "singlePart")
arcpy.management.MultipartToSinglepart(columns, singlePart)
# === Geometry repair and footprint ===
arcpy.management.RepairGeometry(singlePart)
arcpy.ddd.MultiPatchFootprint(singlePart, footprint_path)
arcpy.analysis.CountOverlappingFeatures(footprint_path, count_over, "", count_over_tab)
# === Prepare ===
union_all = []
union_one = []
if arcpy.Exists(count_over_tab):
fields = [f.name for f in arcpy.ListFields(count_over_tab) if f.type != "OID"]
if len(fields) < 2:
print(" Table does not have at least two fields.")
else:
key_field = fields[0]
value_field = fields[1]
print(f"Using: key = {key_field}, value = {value_field}")
result_dict = defaultdict(list)
with arcpy.da.SearchCursor(count_over_tab, [key_field, value_field]) as cursor:
for key, value in cursor:
result_dict[key].append(value)
# === Get OID field and prepare layer ===
oid_field = Describe(singlePart).OIDFieldName
field_name = AddFieldDelimiters(singlePart, oid_field)
arcpy.MakeFeatureLayer_management(singlePart, "columns_layer")
# === Export all single-feature groups at once ===
single_oids = [str(oid_list[0]) for oid_list in result_dict.values() if len(oid_list) == 1]
if single_oids:
where_clause = f"{field_name} IN ({','.join(single_oids)})"
single_fc = os.path.join(gdb_path, "single_all")
arcpy.conversion.FeatureClassToFeatureClass(
in_features=singlePart,
out_path=gdb_path,
out_name="single_all",
where_clause=where_clause
print(f" Exported {len(single_oids)} single-feature groups.")
union_one.append(single_fc)
# === Process multi-feature groups using selections ===
for group_id, oid_list in result_dict.items():
if len(oid_list) > 1:
oid_values = ", ".join(str(oid) for oid in oid_list)
where_clause = f"{field_name} IN ({oid_values})"
arcpy.SelectLayerByAttribute_management("columns_layer", "NEW_SELECTION", where_clause)
group_fc = os.path.join(gdb_path, f"group_{group_id}")
arcpy.CopyFeatures_management("columns_layer", group_fc)
count_group = int(arcpy.management.GetCount(group_fc)[0])
print(f" Exported group {group_id} with {count_group} features.")
if count_group < 2:
print(f" Skipping group {group_id} — not enough features.")
continue
enclosed_fc = os.path.join(gdb_path, f"enclosed_{group_id}")
try:
arcpy.ddd.EncloseMultiPatch(group_fc, enclosed_fc)
print(f" Enclosed: {enclosed_fc}")
except Exception as e:
print(f" Enclose failed for group {group_id}: {e}")
continue
union_fc = os.path.join(gdb_path, f"union_{group_id}")
try:
arcpy.ddd.Union3D(enclosed_fc, union_fc, '', 'DISABLE', 'ENABLE')
print(f" Union3D completed: {union_fc}")
count = int(arcpy.management.GetCount(union_fc)[0])
print(f" Union result contains {count} feature(s)")
if count > 0:
union_all.append(union_fc)
print(f" Union3D failed for group {group_id}: {e}")
try:
# === Final Union: union_all + union_one ===
union_full = []
# Union All
if union_all:
merge_all = os.path.join(gdb_path, "merge_all")
enclosed_all = os.path.join(gdb_path, "enclosed_all")
union_all_fc = os.path.join(gdb_path, "union_all")
arcpy.management.Merge(union_all, merge_all)
arcpy.ddd.EncloseMultiPatch(merge_all, enclosed_all)
arcpy.ddd.Union3D(enclosed_all, union_all_fc, '', 'DISABLE', 'ENABLE')
union_full.append(union_all_fc)
count_all = int(arcpy.management.GetCount(union_all_fc)[0])
print(f" Union ALL result contains {count_all} feature(s)")
# Union One
if union_one:
merge_one = os.path.join(gdb_path, "merge_one")
enclosed_one = os.path.join(gdb_path, "enclosed_one")
union_one_fc = os.path.join(gdb_path, "union_one")
arcpy.management.Merge(union_one, merge_one)
arcpy.ddd.EncloseMultiPatch(merge_one, enclosed_one)
arcpy.ddd.Union3D(enclosed_one, union_one_fc, '', 'DISABLE', 'ENABLE')
union_full.append(union_one_fc)
count_one = int(arcpy.management.GetCount(union_one_fc)[0])
print(f" Union ONE result contains {count_one} feature(s)")
# Final Full Union
if union_full:
merge_full = os.path.join(gdb_path, "merge_full")
enclosed_full = os.path.join(gdb_path, "enclosed_full")
union_full_fc = os.path.join(gdb_path, "union_full")
arcpy.management.Merge(union_full, merge_full)
arcpy.ddd.EncloseMultiPatch(merge_full, enclosed_full)
arcpy.ddd.Union3D(enclosed_full, union_full_fc, '', 'DISABLE', 'ENABLE')
count_full = int(arcpy.management.GetCount(union_full_fc)[0])
print(f" FINAL Union FULL result contains {count_full} feature(s)")
print(f" Final Union3D process failed: {e}")
# Elapsed time in minutes
elapsed_minutes = (end - start) / 60
print("Elapsed time:", round(elapsed_minutes, 2), "minutes")Hello,
i would like to create union from feature class which have more of 2000 features.My iterations is:
- create feature class from gdb
- create MultipartToSinglepart
- RepairGeometry of single part
- create MultiPatchFootprint
- CountOverlappingFeatures
- create Enclosed
- create union of two, tree... pair multipatch which is overloading(first encode)
- merge single feature class
- create encode of merget sigle feature class
- create union of encode
Apear error:
warning stating that the resulting feature is not simple
How to solved problem?
