I've developed a python script in a notebook in ArcGIS Pro and it will run correctly without errors, but the same python code in a notebook in ArcGIS Online fails. Here are the first 3 blocks of my code, its the second block that fails in ArcGIS Online. The 4th code block is the error message from trying to run it in the ArcGIS Online Notebook.
It appears to be a problem with the query on the fire perimeters (fires_url) but I can't figure out what it doesn't like about my query in the ArcGIS Online Notebook.
from arcgis.gis import GIS
from arcgis.features import FeatureLayer
from arcgis.features.analysis import overlay_layers
import datetime
# 🔐 Connect to GIS
gis = GIS("home")
print(gis)# Input Feature Services
fires_url = "https://services3.arcgis.com/T4QMspbfLg3qTGWY/arcgis/rest/services/WFIGS_Interagency_Perimeters_Internal/FeatureServer/0"
ownership_url = "https://services1.arcgis.com/gGHDlz6USftL5Pau/arcgis/rest/services/BaseStaticSnapshotForMobile_LandDesignationsOwnership/FeatureServer/0"
fires_fl = FeatureLayer(fires_url)
ownership_fl = FeatureLayer(ownership_url)
# Filter Fires
FireQuery = "attr_IncidentTypeCategory = 'WF' And attr_FireCause = 'Natural' AND (attr_ContainmentDateTime >= timestamp '2023-10-01 00:00:00.000' Or (attr_ContainmentDateTime IS NULL And attr_EstimatedContainmentDate >= timestamp '2023-10-01 00:00:00.000'))"
selectedFires = fires_fl.query(where=FireQuery, out_fields='*', return_geometry=True)
# Filter USFS Ownership
usfs_query = "OWNERCLASSIFICATION IN ('USDA FOREST SERVICE')"
usfs_ownership = ownership_fl.query(where=usfs_query, out_fields='*', return_geometry=True)
print(f"USFS ownership features: {len(usfs_ownership.features)}")
print(f"Wildfire features: {len(selectedFires.features)}")#Intersect Fires and Ownership. Output to Feature Service with _YYYYMMDD at the end of the name
current_date = datetime.datetime.now()
formatted_date = current_date.strftime("%Y%m%d%H%M")
OverlayName = "Fire_DataCall_" + formatted_date
print(OverlayName)
OverlayOutput_url = "https://services1.arcgis.com/gGHDlz6USftL5Pau/arcgis/rest/services/" + OverlayName + "/FeatureServer/0"
#print(OverlayOutput_url)
# Intersect fires with USFS ownership (KEEP ALL ATTRIBUTES)
print("Running overlay (Intersect)...")
results = overlay_layers(
#input_layer=fires_url,
input_layer={"url": fires_url, "filter": FireQuery},
#overlay_layer=ownership_url,
overlay_layer={"url": ownership_url, "filter": usfs_query},
overlay_type="intersect",
output_type="Input",
# Outputs results as a new hosted feature layer
output_name=OverlayName,
context={"overwrite": True}
JSONDecodeError Traceback (most recent call last)
File /opt/conda/lib/python3.11/site-packages/requests/models.py:974, in Response.json(self, **kwargs)
973 try:
--> 974 return complexjson.loads(self.text, **kwargs)
975 except JSONDecodeError as e:
976 # Catch JSON-related errors and raise as requests.JSONDecodeError
977 # This aliases json.JSONDecodeError and simplejson.JSONDecodeError
File /opt/conda/lib/python3.11/site-packages/simplejson/__init__.py:514, in loads(s, encoding, cls, object_hook, parse_float, parse_int, parse_constant, object_pairs_hook, use_decimal, allow_nan, **kw)
510 if (cls is None and encoding is None and object_hook is None and
511 parse_int is None and parse_float is None and
512 parse_constant is None and object_pairs_hook is None
513 and not use_decimal and not allow_nan and not kw):
--> 514 return _default_decoder.decode(s)
515 if cls is None:
File /opt/conda/lib/python3.11/site-packages/simplejson/decoder.py:386, in JSONDecoder.decode(self, s, _w, _PY3)
385 s = str(s, self.encoding)
--> 386 obj, end = self.raw_decode(s)
387 end = _w(s, end).end()
File /opt/conda/lib/python3.11/site-packages/simplejson/decoder.py:416, in JSONDecoder.raw_decode(self, s, idx, _w, _PY3)
415 idx += 3
--> 416 return self.scan_once(s, idx=_w(s, idx).end())
JSONDecodeError: Expecting value: line 1 column 1 (char 0)
During handling of the above exception, another exception occurred:
Cell In[3], line 10
8 # Filter Fires
9 FireQuery = "attr_IncidentTypeCategory = 'WF' And attr_FireCause = 'Natural' AND (attr_ContainmentDateTime >= timestamp '2023-10-01 00:00:00.000' Or (attr_ContainmentDateTime IS NULL And attr_EstimatedContainmentDate >= timestamp '2023-10-01 00:00:00.000'))"
---> 10 selectedFires = fires_fl.query(where=FireQuery, out_fields='*', return_geometry=True)
12 # Filter USFS Ownership
13 usfs_query = "OWNERCLASSIFICATION IN ('USDA FOREST SERVICE')"
File /opt/conda/lib/python3.11/site-packages/arcgis/features/layer.py:2257, in FeatureLayer.query(self, where, out_fields, time_filter, geometry_filter, return_geometry, return_count_only, return_ids_only, return_distinct_values, return_extent_only, group_by_fields_for_statistics, statistic_filter, result_offset, result_record_count, object_ids, distance, units, max_allowable_offset, out_sr, geometry_precision, gdb_version, order_by_fields, out_statistics, return_z, return_m, multipatch_option, quantization_parameters, return_centroid, return_all_records, result_type, historic_moment, sql_format, return_true_curves, return_exceeded_limit_features, as_df, datum_transformation, time_reference_unknown_client, **kwargs)
2214 # validate parameters
2215 query_params = _query.QueryParameters(
2216 where=where,
2217 out_fields=out_fields,
2250 time_reference_unknown_client=time_reference_unknown_client,
2251 )
2252 return _query.Query(
2253 layer=self,
2254 parameters=query_params,
2255 is_layer=True,
2256 as_df=as_df,
-> 2257 ).execute()
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:658, in Query.execute(self)
655 self._get_url()
657 # Two workflows: Return as FeatureSet or return as DataFrame
--> 658 return self._query(raw)
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:679, in Query._query(self, raw)
677 return self._process_query_result(result, raw)
678 except Exception as query_exception:
--> 679 return self._handle_query_exception(query_exception)
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:843, in Query._handle_query_exception(self, query_exception)
840 if any(msg in str(query_exception) for msg in error_messages):
841 return self._retry_query_with_fewer_records()
--> 843 raise query_exception
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:677, in Query._query(self, raw)
673 # Perform the initial query
674 result = self.layer._con._session.get(
675 self.url, params=encoded_parameters
676 ).json()
--> 677 return self._process_query_result(result, raw)
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:711, in Query._process_query_result(self, result, raw)
707 features = self._fetch_all_features_single_thread(features, result)
708 else:
709 # Otherwise, we use a concurrent workflow with ids to fetch all features
710 # This workflow also works if pagination is not supported
--> 711 features = self._fetch_all_features_by_chunk()
713 result["features"] = features
714 if self.as_df:
File /opt/conda/lib/python3.11/site-packages/arcgis/_impl/common/_query.py:829, in Query._fetch_all_features_by_chunk(self)
827 # Step 4: Process the results
828 for future in concurrent.futures.as_completed(futures):
--> 829 result = future.result().json()
830 features += result.get("features", [])
831 return features
File /opt/conda/lib/python3.11/site-packages/requests/models.py:978, in Response.json(self, **kwargs)
--> 978 raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
