I'm looking to create a public survey that will collect 3 different map points from each respondent. The respondents have to place all 3 point types, and each point type is tied to some predetermined attribute. I suspected there wasn't a way to place multiple different types of points on one map question, but I thought I could ask multiple map questions and then tie the data together later, like so:
1. Place a red point.*
<red point map>
2. Place a green point.*
<green point map>
3. Place a blue point.*
<blue point map>
That seems to not be the case, outside of using a repeat in Survey123 Connect. However, repeats are designed for multiple copies of the same question, which is different from what I'm trying to make. Is there a way to collect points in different categories from one survey?
