I am exporting attachments from an Table with Attachments. I want to combine 2 fields from the base table for the folder name.
This is what I have. I have named the fields FileName1 and FileName2. I just cannot figure out how to combine them
Issues is the name of the origin Table
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2025-07-21 13:23:03
import arcpy
def Model(): # Model
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.env.overwriteOutput = False
arcpy.ImportToolbox(r"c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Data Management Tools.tbx")
Issues = "Issues"
NRPExportTest = "\\\\gisfs01\\GIS_Cache$\\GISData\\RobertTemp\\NRPExportTest"
FileName1 = "ISSUENAME_W"
FileName2 = "WORKGROUP"
output_filename = f"{FileName1}"
# Process: Export Attachments (Export Attachments) (management)
Output_Directories = arcpy.management.ExportAttachments(in_dataset=Issues, out_location=NRPExportTest, subdirectory_field= output_filename)[0]
if __name__ == '__main__':
# Global Environment settings
with arcpy.EnvManager(scratchWorkspace="\\\\gisfs01\\GIS_Cache$\\PortalServices\\PGIS\\FieldMarkups\\FieldMarkups.gdb", workspace="\\\\gisfs01\\GIS_Cache$\\PortalServices\\PGIS\\FieldMarkups\\FieldMarkups.gdb"):
Model()
