I know this has been discussed extensively in the past, but I wanted to start another thread on the topic because I'm still struggling to understand why this is happening.
I've created a polygon hosted feature layer in AGOL, and I sketch an area in Pro, Web Editor, or Field Maps. The shape-area comes back as abc square meters, but when I use a measure tool in either an instant app or in Pro, and trace over that area, the result is xyz square meters. In other words, the results are different.
I've read numerous posts stating that the issue is that the data/map is in Web Mercator, and therefore, the measure tool utilizes the distorted effect from the projection.
What is the scoop on this, and how can I get these things to line up, especially in Field Maps, where my field workers are seeing that default acres number when they select a feature, at odds with the actual shape-area value converted to acres?
